Question about In Microwave Ovens
How to change the torsion spring in kitchen aid microwave oven
    Master:
  • 505 Answers
Try these links to get more information about replaceing this spring.
How To Change The Torsion Spring In Microwave Oven Microwave Repair
Posted on Feb 12, 2015
6ya staff
SOURCE:
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
How to change the torsion springs in my kitchenaid microwave oven KEMC308KSS01
Replacing the spring isn't very difficult if you're mechanically inclined.
You're basically removing a few screws, the front panel of the door is removed exposing only the glass part that's still hinged. The springs are exposed. Hopefully one spring is still in tack so you can see the orientation of how to put the replacement in. It's not very intuitive on how to do this part.
Check this link for more details:
Microwave Repair
Feb 12, 2015 | KitchenAid Microwave Ovens
Door spring on build in microwave oven
Is this a combination built-in oven with microwave on top? And is this microwave one in which the door opens downward like a regular oven? If so, then this is a common problem for this oven/microwave combo, but replacing the spring is not a job for amatures. It takes a professional 45 minutes typically to do this job. It involves removing trim pieces, removing screws that hold the microwave oven in place, pulling the microwave out a couple of inches, and taking the door apart to get to the 2 torsion-bar springs. Replacing them is quite tricky, as is re-assembling the door. I recommend calling Sears Service (1-800-469-4663) to get a seasoned repairman to come out and fix your oven/microwave. Cost will probably be between $180 to $200.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 25, 2015 | KitchenAid Microwave Ovens
Door spring on microwave
KA MW use torsion springs 2 about 50 a piece
How do i remove the halogen light in my micowave
I have a similar Kitchen Aid model. The little light inside my unit also went out. I called Kitchen Aid and they scheduled a tech to come out to change it. He said the only way to get to it is to pull the unit out from the wall (it's a built in unit). $150.00 bucks later I had a light for about another year before it burned out too. Needless to say, the heck with it, I don't need the light that bad.
Nov 16, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
How to replace torsion spring in the microwave door
If this is the flip down door. You will need to take apart the side cover of the unit to fasten the spring. Once you have done that you need to put a pen or something to hook it so it doesn't drop down in the unit. If you are unable to hook the spring in the door. You must take the outer cover off the door to hook the spring and then replace the cover. You may find this to be a two person job and may be easier to hook the door before you hook the unit. Some doors are different then others.
Feb 08, 2011 | KitchenAid Microwave Convection Oven
Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 24, 2008 | KitchenAid KHMS147HS Microwave Oven
Microwave Ovens Logo
125 people viewed this question
Top In Microwave Ovens Experts
vince
William Miller
William Miller
Giulio Moro
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
