I fixed my Headphones that would not stop vibrating by leaving them ON until the Power drain out and they stopped vibrating. Then Turned them OFF, plug in the charger they began to Vibrate again but after the charge they Stopped Vibrating and have been ok ever since
Hi, well i guess you have tried setting the settings and turned it off? if not then well do that, however IF it is not that and you cannot stop it, try a factory reset, then you will have to set the phone up all again but if it works it is a small price to pay? In any event if it will NOT stop vibrating, then you have a microprocessor fault, and the phone will have to be repaired or replaced? If so you need to take it into an LG phone repairer and ask for a "Quote" as to what it may cost, and go from there.
go to setting and check for vibrating if that won't work turn off the sound call the phone if it don't vibrated change it open the phone order parts from Ebay
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
