Going to display settings on the control panel but nothing has changed,the screen is still fuzzy.
SOURCE: Screen problem
Go step by step: 1. maybe you are trying to set a higher resolution then the screen can be 2. its possible that your comp don?t recognize the screen right, check the "display properties" make sure it?s the right model 3. reinstall the drivers. Restart. 4. if its not the software it?s the hardware, try connecting the screen to another computer if it works fine the problem is in the display board . Good luck
SOURCE: Monitor resolution can't be changed
some 15" monitors do not support 1024 by 768, check your monitor specifications if it does. google on the net with the exact monitor model no. and see if it supports.
1. Make sure your computer is off.
2. Turn on computer then tap F8 repeatedly once per second. Similarly, Windows advanced options menu should be up on you screen.
3. use arrow keys to highlight "safe mode".
4. press enter twice.
5. log on to your user profile
6. you will get a window asking you to press "yes" or "no". CLICK the YES button.
7. perform the next steps below according to your windows version (operating system)
In Windows XP
