The heart rate readin gon my Polar F11 has started to show as very low - I would estimate to be working at 70-80%, yet it is showing at about 30-40% and does not increase in line with an increase in my exercise. This problem has started within the last 2 days, and I have been using my monitor for the previous few months with no problems.
Try this link for the manual.
polar f11 heart rate monitor manual Google Search .
However, you may wish to reset the unit and start over with new settings. You can resetyour Polar F11 by following a few easy steps. Press any button to activate the Polar F11 Fitness heart monitor unit. Press all buttons on the Polar F11 Fitness heart monitor simultaneously, except the "Light" button.
How to Reset a Polar F11 ' Healthfully
https://healthfully.com/reset-polar-f11-7176556.html
reset polar f11 heart rate monitor Google Search
SOURCE: Polar F6
It sounds like most of you have the heart rate set to display in % of max heart rate. Most Polar products have the option of heart rate in BPM(beats per minute) or percentage of max.
If you look at the display during the exercise, you will see a % icon. You can turn it off in by hitting the back button and go down to HR view settings.
Hope this helps.
Chris @ Polar USA
SOURCE: Polar F11 not responding
I' advise to start with battery check. If the battery is ok, then you will need a professional to find the cause of malfunction.
SOURCE: lost manual for polar F11
Paste this link into your browser and download manual:
http://www.polar.fi/en/support/downloads?product=&category=User+manuals&documenttitle=User+Manual+for+F11+in+English+9%2F2007-&document=/gip/PKBStoGIP.nsf/web_cat/C225742500419A8AC225732F0049BE55
Do not forget to rate, please.
SOURCE: How to change the battery on a Polar F11 Heart Monitor
Here are instructions (with images included) on how to replace the battery for a Polar F11: http://timlaqua.com/2008/09/how-to-replace-the-battery-in-a-polar-f11-heart-rate-monitor-hrm/
SOURCE: Battery in a Polar F7 heart rate monitor
Hello
You can change the battery in your polar f7 if the battery is worn out.
1. Insert the tip of a pen knife into the lifting point and lifting the back up. The back of the watch is only pressed into place and will come off easily this way.
2. Grab the small clip that is extending across the surface of the battery with a pair of tweezers. Slide the tweezers toward the end that hooks down into the watch. Pull the hook end of the clip out of the watch and remove the clip from the battery
3. Match the old battery with a new one at any electronic store. The store will be able to read the writing imprinted on the battery to make sure that you get the correct battery type for your heart monitor.
4. Press the new battery into the watch making sure that the writing on the battery is facing up.
5. Press the holding clip back into place. Handle the clip with tweezers only, since it is very thin and can be bent or lost easily. Once it is in place, press the back of the watch on.
GOODLUCK
u may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
Instructions
You may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
Instructions:
