Quite easy to transfer computer pics to flash drive via Windows Explorer:
1. Plug USB flash drive and iPhone to computer. iPhone will receive a prompt to approve it. Approve it and iPhone will be automatically detected by computer.
2. Open Windows Explorer and head to "iPhone > Internal Storage > DCIM". A list of photos on iPhone will show up.
3. Hold "Ctrl" and select photos you would like to transfer to USB stick and press "Ctrl + C".
Windows Explorer is pre-installed in Windows computer. In other words, you don't need to download or install any 3rd-party software to accomplish how to transfer photos from iPhone to USB stick. Within a few clicks, you are able to transfer iPhone photos to USB flash drive. Now learn how by the following steps.
4. Create a new folder in USB drive or find a folder, then press "Ctrl + V" to transfer iPhone photos to USB flash drive.
You can do this yourself Insert the disk into a working computer's CD drive and copy the folders onto an USB flash drive, then insert the USB flash drive into your Toshiba and copy the folders off the USB flash drive onto your Toshiba.
To transfer files from an old computer you can use USB or flash drives, copy the files from your Old Computer to Flash drive, after copying---attach the flash drive to your new computer then copy the files and save it. This is the easiest way to transfer files.
Other way of transferring;
-You can also transfer files by Burning your files into a CD/DVD and copy it to your new computer. -Get your hard disk from the old computer and attached it to your new computer -Or connect/network your two computers.
I recommend USB or Flash drives, the simplest and easy way.
If you will be using a blank cd then you will be needing a burning software e.g Nero for you to transfer your data files to your cd. you may use also a usb flash drive to transfer you files from your computer to other computer.
If you're working with a USB flash drive, just insert the flash drive into the USB slot. You can open the flash drive in "My Computer" and "Copy and Paste" your files or you can open the folder where the files that you are wanting to transfer are located and "Drop and Drag" them to the flash drive.
The flash drive's drive letter isn't the same on all machines but is usually located after the optical(CD/DVD) drive.
you can make you flash drive bootable.. the problem is that it might not necessary copy over the recovery cd files properly. Here is a link that can help you: http://www.bootdisk.com/pendrive.htm
