REPLACE LAMP
You must follow instructions very carefully when replacing the lamp. Chances are the door did not get shut tightly allowing an open circuit to the door switch and the fan. If the fan is not running you must go back and make sure the lamp installation is right. also, if you did not purchase an exact replacement lamp it may be defective. If the fan is running then the chance is for a bad lamp. Hope this helps.
