Within cardfive, check your printer setup settings before going to the print screen. You have to define the output device first, and separately. If this doesn't work, close cardfive, go to the Windows Devices & Printers screen (within Control Panel) and set your card printer to be your default output device (right-click the printer, "Set as Default ..."). Then open cardfive and see if it now directs to print, rather than presenting the "Save" option.
If it says save, I'd suggest the printer has been set to PDF or some such, or the destination has been set to FILE:
Testimonial: "It is set to file, but that is what it is set to when a co-worker signs in on my PC and it prints correctly. As you noted, when I take it off the file designation, the SAVE screen does go away...it just won't print."
