I have a double oven, model RDB245 PDQ12. The range heats up for the first five or ten minutes, then the panel shows E6 F2. I am assuming these are codes? This happens on either oven.
Thank you for your inquiry, Bego?a Rebolledo-Kaufman!
From the information you have provided you are experiencing an issue with your Frigidaire double oven not heating. It sounds like a possible problem with your element or thermostat. I would suggest to perform a reset on your range, to see if that would help correct any miscommunication within the electrical components. In order to reset your range you would need to flip the household circuit breaker off for ten minutes. If you still continue to have an issue with the oven I would recommend having a professional technician out to provide an accurate diagnosis and replace any electrical parts needed inside of your oven. Hopefully this is helpful to some degree. -Matt
Thank you for your post, friend!
I see that you are having some challenges with your Frigidaire range. On your control panel if you have a "Clear" or "Cancel" button you can hold that down for five to ten seconds and it should release the latch. You can also hold down the light switch button on the oven door frame and the cancel button simultaneously for five to ten seconds to see if that would correct the problem. Last, I would perform a reset on your range which can be done by disconnecting power from the range for ten minutes. I hope this has been helpful. -Matt
