I've tried a new remote and unplugging and resetting the set
If the TV responds to the remote, then the sensor is working. Likely you have another issue related to the TV function internally. Check that you have a picture or sound and report back.
Sorry, should have made it clear, television is fully functional apart from not responding to the remote after coming out of sleep mode. It works fine with a freeview or dvd player fthrough both the scart and hdmi connections.
SOURCE: lg lcd tv remote code
HI,
BUY A NEW REMOTE FROM E-BAY OR PARTSTORE.COM,TRY A UNIVERSAL ONE IF STILL DOESN'T WORK TV INTERNAL IR INTERNAL RECEIVER IS FAULTY,THANKS.
SOURCE: television will not turn after a 10 minute power outage
Depending on what made the power outage, your power supply might have got fried. It might be as simple as a few capacitors blowing or a little more serious. I would suggest taking it to a repair shop. A power supply replacement will run you about 200-250. If its just a few capacitors, should be around 100.
SOURCE: Neither of my remotes (1
Tries take both remotes controls pushes all the funsctions butons one by one on the front of a turn on Digital Camera,see if u will able to see all the INFER RED signal white light will flashing on the Digital Camera viewing screen.To make sure both the remotes are working and all the buttons are have INFER RED light signal out.Tries pushes all the tv manual buttons on the tv side too see if it is funsctioning too.If all these work testing work,than take some rubbing alchahol put on a rag clean the INFER RED sensors signals on the tv an the cable box by the tv power light LED indications lights.Tries these steps,make sure tv manual control tv side panel work and both remotes works and clean both INFER RED sensors on cable box and tv make it work better.Unplug the cable box for an hour for it to reboot and updating it softwares.Replug the cable box and now tries the tv remote or cable remote again,should functions now.
Testimonial: "Totally rocked - I couldn't find the answer anywhere else online and I got the information right here after a few questions and a little digging."
SOURCE: Vizio 32L, remote sensor malfunction
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
