SOURCE: SRS light on 1997 acura CL
1.bend a paperclip into a u shape. 2.disconnect the yellow plug in your fuse box under the steering wheel and insert the paperclip into the plug that is now hanging there to complete the circuit.3.turn the ignition on and the srs light will stay on for 6 seconds, then turn off.disconnect the paperclip within 4 seconds after that and the light will come back on.4. reconnect the paperclip within 4 seconds and the srs light will turn off again.5.within another 4 seconds of it going off, disconnect the paperclip and the light will blink letting you know that you have completed all the steps right. you can also use some speaker wire
SOURCE: how do i reset maintenance light
hold select and reset buttons on dash at the same time then turn on ignition and continue to hold until light goes off
SOURCE: 2002 Honda Accord. SRS LIGHT CAME ON
Open the door of both sides (driver and passenger) and look for the panel for the fuses. Remove the panel and you will see the fuse box. The information of the fuses is on the panel.
SOURCE: 2001Acura RL 3.5 SRS problems
As you already know The Supplemental Restraint System (or SRS) is the system that controls
your airbags. Unfortunately, there are MANY things that trigger this
annoying light, and to making it go away can cause plenty of headaches.
Things that can cause the SRS light to turn on include:
The Car Scanner
Trouble Code Reader is for real-time automotive diagnosis based on the
OBD2 protocol. By simply plugging it into your vehicles diagnostic
socket, you will be able to Read any trouble codes related to the
"Check Engine Light" and identify the code by consulting the manual. It
will also Erase or Reset the Check Engine light. this should tell you wich sensors are out or giving a faulty signal if you do not wish to invest in an obd2 code reader call you local autozone or advance auto parts and ask if they do free obd2 readings most do and they sell the parts you are most likely going to need I hope this helps ...............good luck
SOURCE: Radio code for 2002 Acura RL
You need to get the serial number off the sticker attached to the radio and the nav. It will require pulling apart your dash. Call an Acura dealership with that serial number and they should be able to provide you the code. Or you can take it directly to the dealer but you will be charged labor.
