you can't start by just resetting the networks settings on the iPad and power cycling the sound bar.
if the issue persist then plug your iPad into a computer with iTunes, back up and restore the device. Set the Device up as new. If the device can now connect to the sound bar you can try to restore from the iTunes back up you created. If the issue comes back when you put the info back in the device then you will need to set up as new.
if the is still not resolved and you know the iPad can connect to other Bluetooth devices then you will need to reach out to Denon.
It's fairly easy to set up usually. With the keyboard powered on there is usually a button that turns bluetooth on and a (usually) blue light will start flashing. At this point on the iPad you look in the bluetooth settings page and look for the keyboard to appear in the available devices. Tap the link to it and follow the instruction. The blue light should stop flashing and remain lit and the iPad BT settings will show that the keyboard is connected.
check the manual...!
depends on the model - but it works with bluetooth- see a sample :
put the iPad in the slot built into the keyboard, and pair it with your iPad via Bluetooth
On your iPad, tap the Settings icon and then tap Bluetooth. Make sure Bluetooth is On. Connect the Logitech Ultrathin Keyboard Cover i5 Logitech Support Article
I have similar problems with my Targus keyboard connection to ipad w/ ios 7, but not yet found solution. In my situation, connect can only be made after a complete power down. Keyboard is on; Bluetooth is on; iPad says it has discovered and connected to the Targus Versavu Keyboard, but keypad does not respond.
