My dvr H.264 16ch offline since i bought it.Every cable is connected from the dvr to router d-link 3G wifi dwr-113 and internet is avaible in the Vodacom modem i use.i don't have adsl at home so i use
It is not going to work. Both wifi and ethernet are for internet connection only. Ethernet is much faster than wifi. Also there is possibility to damage tv by plugging ethernet cable which is connected device using POE (power over ethernet). You need to connect your dvr via hdmi, component or composite cable
Most tablets connect to the internet through WIFI. Only a few can use SIM card to connect through 3G or 4G data connection. For WIFI connection, you must have a WIFI router at home. You will normally password-protect the WIFI rounter. To connect the tablet to the internet through the WIFI-router that is in operation, you will configure its WIFI settings to match the router's password. This will be done by going to tablet's Setting, turn on WIFI, click on your router in the list of detected routers, enter the password when prompted. Ensure that Connected is shown against your router. You can then browse the internet.
Yes you can connect the LAN ports with a network cable from your 3G router to one of your old router LAN ports
Before connecting the 2nd router:
Check it does not have a conflicting IP.
Check it is in the same subnet
ie if 3G router is 192.168.0.1
Set old router to 192.168.0.10
subnet mask 255.255.255.0
gateway is 192.168.0.1
DNS 192.168.0.1
Set DHCP off on 2nd router.
Set WIFI to Same SSID, same password and authentication
ensure it is on a different channel though.(not automatic on either)
Finally just to make sure remove any WAN settings from your router, any old ADSL config etc so that it doesnt think it is a gateway.
You need to access router menu . Try 192.168.0.1 in your web browser address bar. You can really screw things up if you don't know what you are doing. Get the manual and read it 1st.
Generally all laptops with wireless built in have a shutoff button for the wifi connection. While you need the internet turn the wifi off. When you need to print, turn the wifi on, print then turn it off. It is not the best solution, but it should be a short term work-around. The other option is to attach the printer to your laptop with a cable (usb or otherwise). Turn the wifi off. Add more info to your request if this does not solve your problem,
