What does this mean, the water won't empty and the door locks error code showing is f-05
Washing machine WT741 ultima all light are flashing and it won't do anything else
The wt741 I have got was showing F05 fault. I cleaned out the obstruction in the pump and restarted the machine. The machine came started to cycle but then stopped with the display going blank. I unplugged the machine and left it overnight. I restarted it and the display is showing and I can select different programmes but it won`t start help!
Had the same problem a couple of times with my Hotpoint Aquarius. Problem was due to water not being able to drain due to a blockage (sweet wrappers, hair, money and computer games !!". Open the back access panel and loosen the big jubilee clip holding on the rubber drain. Clear any blockage and put unit back together. (All with POWER OFF)
error 3 message appears. Machine will not spin. Water and washing in machine.
After couple of minuts starting the cicle mashine stops and gives the error code F05
after about half way throgh the wash cycle the machine stopped and error code f-12 has appeared on the display, nothing i have tried to do has removed this, door has remained locked so i cant get my washing out off the machine
I have a Hotpoingt Ultima WT741 which keeps throwing up a fault code F-05 what does that mean?
