Bosch Axxis WFL 2060 Front Load Washer Logo
Posted on Jul 07, 2009
F05 Fault code
I have a Bosch WFP3201 washing machine with a F05 fault code coming up on all programs. This is not allowing the drum to turn in wash or spin cycles.
I have ensured the pump is rotating & pipework is clear to drain.
Could this be the motor, brushes?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
641
Points
This will be the motor brushes
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
tip
How to fix Bosch Classixx 6 washing machine pump fault
My Bosch Classixx 6 Express 1200 washing machine suddenly developed three faults at the same time, with no fault codes. The water pump, fill and spin cycles all stopped at the same time. I found that the one of the pump wires had come loose from the connector plug. This will not only stop the drum from emptying but will prevent the machine from filling and also stops the spin cycle. These are all interconnected and controlled by the water pump, which has to be working and connected. Hope this helps. My 11 year old machine is now working perfectly. ,
on Feb 23, 2019 • Washing Machines
HOTPOINT WASHING MACHINE aq9f49u f05 fault code is coming on
Hello , I have the F05 fault also ... I have changed preasure switch and have checked the pump and no blockage. It goes through half a cycle then the F05 fault comes up and flashing lights .. Question ... should the pump turn freely if you turn it with your finger ?? Mine sort of judders ... Also when you tru it on a wash it does not draw any water in ??? Can you help please ??
thanks in advance
Malcolm .
8helpful
Fault code F05 on an indesit washing machine WIXE 167.it not emptying the water
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove large black fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hop[e this helps you.
3helpful
Error code fo5
f05 is normally a fault cause by the pressure switch - often caused by a blockage in the exit hose of the washer. if the water cannot leave the washer in time the f05 will come up because the pressure switch has not told the machine it empty. on hotpoints there is a filter inside the exit pipe from the drum to the pump which gets blocked up. need to remove and clear out the sump assembly and this normally fixes the f05 error. if this does not cure the issue then the pressure switch is probably faulty but its notmally just a blocked pipe.
1helpful
I have a bosch washing machine. The tumble lights are blinking and I cannot get the machine starting a new program
Restart the machine and repeat the following procedure to reset the machine to original factory settings.
Enter the test program by:
1. Set the cycle knob to any "X" (reset) position
2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button
3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds)
The digital display will show 00 for no faults or will show a fault code.
To end the test program turn the washer off at any time.
Post the results.
The result would be a fault code which indicates the error. Will await your further comments.
2answers
Fault code on washer/dryer
Hi.
F05 means pressure jammed on full or pump not draining.If pump o/k, then you will neeed to call an engineer.
24helpful
2answers
Hotpoint WT965 ultima fault code F05
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
