Tried turnin up volume
Pull the sherwood power cord from the wall for 20 minutes. On the back of sherwood, check all cables and make sure they are in the correct places. Check speaker wires and make sure they are connected. 1)After 20 minutes, turn power on to sherwood. 2) select an input (radio, cd, etc.) 3) Push play. 4) Turn volume to desired level.
SOURCE: need remote code for sherwood
Comcast came and the receiver / tv was not capable of being run by another remote as far as volume, just off and on
SOURCE: sherwood rx-4109 power shuts off
The output transformers may-be gone
looking at +$50 AUS
for just the parts
or a licensed service
for about $150 AUS
SOURCE: trying to program my At&t Uverse remote to my
Sherwood
Receiver/Amplifier
5027
Sherwood
Receiver/Amplifier
5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
All the Mode keys should flash twice.
SOURCE: keeps turning itself off
If Both speakers are working at a low volume and you turn it up and it clips and shuts off you have one of 3 problems. you have over driven your speakers and one has shorted the voice coil but still will work at low volume, its a overload protection for ohms short in receiver. unhook each speaker and turn balance to the one hooked up and turn up receiver if it shuts off do the same with other speaker to determine which side is bad. 2 speaker wires are touching at speaker or receiver. 3 a bad receiver output transister. Good luck.
SOURCE: I need a code to
Hello! Try the link below this should help:
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
DISH Network Customer Service
Unlike the budget stereo receivers now flooding the entry-level price points at dealers across the country, the Sherwood RX-4109 is designed and built in-house with the same quality and attention to detail we have been bringing to our audio gear for the last 50 years.
With 105 Watts RMS per channel, phono section, binding posts, a versatile remote control and switching for two pairs of loudspeakers, the only thing that bespeaks the word "budget" about the RX-4109 is its modest cost.
MSRP 179.95
