Tried unplugging connections and reconnecting.
If the TV powers on and stays on.. sounds like you might be on the wrong video stream, (make sure u are using the same input as u are using the output on your cable box, satellite box, etc. if you are using HDMI , use your remote for the TV and find the Source or Input button and try each of the video streams that are listed.
SOURCE: Samsung TV Power Supply Board
I doubt that moisture damaged the SMPS bd.
There are many circuit boards in your set and it will take a trained samsung tech to find the problem.
SOURCE: I have Samsung UN46B8000XFXZA LED TV. After power
Yes based on your testing it appears that the power supply is at fault solely and you can opt to attempt a repair or replace it altogether. Unfortunately you will not be certain that the main board does not also need to be replaced until you have repaired the power supply.
SOURCE: Samsung PS42B430 42" Plasma tv. LED flashes and
The tv power supply board have more dead components parts,u just don't have the skills an the know how to trouble shoot find out more dead components parts that all.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
SOURCE: SAMSUNG TV HAVE POWER BOARD PROBLEM
Gamble? a lot of symptoms thought to be power board are not there at all.
Correct method for someone with knowledge is check all voltage into and out of the power board ---other wise you might just as well get a dartboard out and throw things or parts at it and hope........
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
