SOURCE: servis 1200A caress washing machine trips electric
A wiring harness may be loose and the vibration has worn through the insulation. Put it on the side and take a look for loose wires and rubbing.
SOURCE: servis m6160w logic 1600 tripping rcd
many servis have an induction motor but later models have a brush motor.
worn brushes will not cause an earth fault. suspect part of the motor windings are down to earth. also possible you have a leak in the tub or door gasket so that on spin, water is thrown onto an electrical item
SOURCE: Washing Machine does not start
It could also be your line to the machine is fried at the ends where the electrical hook up is. Look at the connections on the back of the machine. One may be fried
