Check battery voltage is over 12.0 VDC and fuse is intact.
The unit requires Brake ON, PTO OFF, and both steering arms out (neutral) to crank. Cycle the components Brake, PTO, and steering arms and try again.
There are no relays, just switches. The wiring diagram is in the operators manual available no fee download from multiple sources including CubCadet. Some alternative part suppliers include the wiring diagram in the parts list.
Nothing available online, but you could ask the spares suppliers. It can't be that complicated, wires in, a switch and a small control board from studying the diagram.
generic wiring schematics seldom match the OEM wiring as to get the diagram the book publishers have to virtually strip down a vehicle as the diagrams are copy write protected. IN many cases the manufacturers of the vehicles change wiring harness suppliers and the OEM schematics will vary to your vehicle. When in doubt take it to an installer and have them fit it as diy people generally install incorrectly and produce faults in the CPU program
Hi! I got an old wash extractor, type wpb3890h and i can't seem to figure out how to connect its limit switch on the belt side of the machine as a result it wont start wash. Any wiring diagrams or pictures i might need to see?
The only place that I know that has a wiring diagram is the factory shop manual which is available thru any thunderbird restoration parts suppliers or ebay. If the electronic ignition, they called it transistorized ignition in 66, is original, you might consider changing to a point type ignition or a later electronic ignition or aftermarket like Petronics. The parts for the original transistorized ignition are very hard to find and even more pricier.
http://www.ryobi.com.au/ within this web site if you look under service outlets gives you the stores that are closest to you that sell ryobi equipment i looked and found dubbo mowers and chainsaws ph 68823122 they might be able to find one for you hopefully bestaluck glenn
