SOURCE: hooking up game system to flat screen tv
you should have several kinds of inputs options on TV .If you have a surround audio receiver .Simply go direct to receiver on any available input .If using diect to TV , use any available input on TV .More likely VIDEO 1 or 2 (game or camera input)on front or side of flat panel
SOURCE: 47'' philips flat screen does not install channels
Go directly to theback of the set via the back RCA connectors(yellow, red, white) or component video, and turn set on Aux. If it works the tuner is Messed!
SOURCE: I'm trying to hook my DVD player to my Emerson
the tv should already have a place where the yellow red and white cables fit on the back usually if not, you would have to go to your local radio shack or source or a store like that and pick up a rca to coaxial converter theyre like 20 bucks depending on where you go then you can just plug it in accordingly and then youre golden
SOURCE: Model 232-S12 The screen is
Hello
If you have forgotten the entered password, press "9999" to lift the passward lock and chage to new prefered password, and keep this password safe for further use. Ok
Pressing "9999" to the now asked colum wil lift the present lock and allow you to enter a new password.
SOURCE: I hooked up a rca digital flat antenna and cant get any channels it just stay on channel 3
check the settings in your tv .
