The first time when I started DVDR with remout controle it showed only Hellow. After thet I disconected it and again conected to the power it didnot work any with mehanical swich and of course with remoute controle. Even there is no and Hellow
SOURCE: dvdr610
If you just purchase a new universal remote control. You need the manual that came with remote. Inside you should be able to find your brand of DVD player and the codes to activate it. Since all Universal Remotes are different there's no set procedure that will work for all of them. You will need the manual and go through each step to set up correctly. If you don't have or misplaced manual, you might need to contact manufacturer to either replace manual or receive the codes. Good Luck
SOURCE: Start problem
The remote is not working properly. If possible get the remote serviced at any authorized center & if not serviceable you have no option but to replace the set with a compatible set.......sodeep
(but before you do that if the remote has batteries and they have been in use for quite some time then change those batteries & give it a trial)
SOURCE: How can I switch Inputs on my Emerson EWF2002 TV
You can't. There is no option for changing the input in the Menu and no Input button on the TV.
However, you can get a substitute remote here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=EWF2002&uuid=12901104268770 . Alternatively, get a universal remote that matches the feature (probably not the cheapest ones) and try several codes until you find one that makes the feature work. (Sometimes a code that works for on/off doesn't do the rest of the features). Another option would be a programmable remote - the type that are programmed via a USB connection to a computer.
I wish that I could be of more help.
SOURCE: my remoute control joust change
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
To convert this player for multi-region playback
This hack should work on all Philips DVD players with any firmware version, and other similar models by manufacturers such as Grundig, Marantz and Yamaha
Please note that if you experience problems with this hack you can obtain firmware version 7.03 and later by visiting the PhilipsSyndicate to obtain files that you can burn to a CD-R and flash your unit to the new version.
1a.
The following uses the machines own remote control:
We have heard reports that hacking some players using the units own remote control incurs a 25 change limit after which it will lock the machine in the last set region
We have heard other reports that hacking some players such as the DVDR-880 using the units own remote control can result in an inoperable unit, we recommend you use the OneForAll remote only and consult our Region Hacks forum for more information
If the above does not work, you will have to send the infra-red code RC6 (aka Codeset 4, Key 235 in nerd-speak) to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital with the following instructions:
NB: Sending these codes to some players, such as the Philips DVDR-980, requires you to select a DVD player remote on the unit as the default IR device, as opposed to the DVD recorder remote it is factory set to. Please consult your player documentation to find out how to do this.
2.
The onscreen display should show 11 spaces like this: '-----------'
NB: The actual display may differ slightly depending on the model of your player, may be shown on the unit itself, or may even not be visible on some models at all.
3.
Using the number keys on your DVD player's remote control, enter the code 222 222 005 255. Note that this is 12 digits and the last digit will not show on the on-screen display.
NB: For players such as the Philips DVDR-980, DVDR-985 and DVDR-1000 units, you may need to use the code 121 212 005 255 instead. For players such as the Philips DVDR-880 you may need to use the code 121 212 005 00x instead, where x is the desired region, however this also works on other units including the DVDR-985 for setting a specific region.
4.
Press the Play button on your DVD player's remote control
5.
The onscreen display should now show the words No Disc
6.
Power off your DVD player, wait 10 seconds and then power back on
