I have refilled the Lexmark 32 black ink cartridge that came with the printer, and it does not recognize the refilled cartridge. I get a message that tells me the cartridge is out of ink and that to use non Lexmark cartridges will void the warranty. I paid 79 bucks for the printer and a black and color Lexmark cartridge at Office Depot is $59. I need some help on how to reset this printer to recognize the refilled cartridge. Thanks, Mark
I refilled my lexmark 24 color cartrgide but now the printer does not want to read the cartridge, any help on resetting the thing before i chuck it trew the window
Just unplug the printer from the back and plug it back in. Problem solved. I did this on my mother's printer and it worked like a charm for this same error msg and issue.
It works fine if you use the high volume cartridge (34) -- odd, but tru
I have saved THOUSANDS by refilling Xerox fax , cannon and HP and yes Lexmark cartridges over the last 8yrs or so. This was the subject of some litigation last year as there is a company that sells a Lexmark after market REFILLABLE cartrige for these latest generation printers. Lexmark took them to court last year claiming copyright infringment on the chips in the cartridge and last report in the media was the judge had issued a injuction pending the outcome of the case to ALLOW the aftermarket cartridges to continue to be sold. This problem is built into this unit, that is it is designed so you cannot refill the cartriges; there may be a hack solution but I have't found it yet and I just hit the "check mark" buttion a couple of times to get my FAXES to print from memory as I dont have this hooked up to a computer, just using it as a fax/scanner/copier stand alone at the moment. Dang lexmarK!!!
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
922
during printing got message NeverErr:0x960F. What does it mean, can't turn off printer either.
This seems to be a common problem, according to a fair amount of research I've done on it........even with new cartridges! People have tried unplugging their printer, have been careful not to touch the contacts, have done a cartridge dance, and the printer still either a) does not recognize the cartridge or b) shows a low ink level.
A person closer to the industry than I suspects that the contact strip is not made very "robust" and wears out easily......another explanation is that the printer actually destroys a contact gradually while the ink is being used so that it's literally wiped out, so that a refill will still register as an empty cartridge, because the "gas gauge" shows empty. The problem is the worst with the 31, 32, 33, 34, 35, but I've also run into it with the 82's.
Hope someone comes up with a solution, otherwise Lexmark wins!
refilled cartridge shows up empty in the printer :-??
Does anyone know how to fix this? I refilled, and it doesn't even print anything out. It says NeverErr Ox960F and isn't turning off when I press power. I'm afraid to unplug this sucker in case I mess it up completely. does it not work with refilled cartridges or am I doing something wrong?
it;s leaking out when I print.
I have refilled the Lexmark 32 black ink cartridge that came with the printer, and it does not recognize the refilled cartridge. I get a message that tells me the cartridge is out of ink and that to use non Lexmark cartridges will void the warranty I need some help on how to reset this printer to recognize the refilled cartridge. Thanks, FRANK
i put in a brand new lexmark 24 cartridge in my x3430 lexmark printer and i got this same error code. it won't turn off. i have only had this printer for a month and it is doing this...arrgh!
this was a brand new, lexmark cartridge and it won't take it or turn off.
I have the same problem. CAn anyone help. Message shows Left Cartidge incorrect and it's a genuine LM 32> Any ideas? [email protected] cheers
I filled the fax machine with new ink and it say left cartridge missing and it wasn't.
I rmoved the empty 33 color ink for lexmark that I purchased at a printers store and inserted the new cartrige (same 33 color for lexmark x5470)
when I lowered the printer's cover the printer wanted to start an alignment test. I loaded plain paper and pressed v.
it tells me a problem that I didn't take away the tape. (but I did)
it tells me that I'm out of color ink.
