Having trouble trying to charge a 2 month old Acer icona one 7 tablet . Every time I plug it in it says that it's charging. When I check in it a hour later . I has on the display "plug in , not charging". The cord. & charger work fine. Has anyone else had this same trouble with their tablet?.
First of all these tablets take a long time to charge. second check the cable were you plug into tablet to make sure the holding clips are working and take hold. My first choice and most inexpensive is to buy a new charger. Also check plug in port for damage. look at warranty to see if it is still covered and get replaced. />
The owner's manual that came with it should have the answer to your question.
SOURCE: My Dell Streak 7 Tablet will not charge. When the
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
SOURCE: Can't charge the ipad from the USB charger
To get Ipad to show as charging download Asus AiCharger from web and
restart computer after install.Plug in usb from Ipad and should now show
charging
http://event.asus.com/mb/2010/ai_charger/
Please Rate
SOURCE: fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
SOURCE: I have an Asus Memo Pad HD 7 which I purchased 3
the more programs you install and run in the back ground the more the battery is drained. It comes to a point where there are so many programs running the gadget cannot run & charge at the same time. It might charge better if you uninstall a lot of programs or do a factory reset but that is drastic
Testimonial: "I did do a factory reset but the icon is still not showing and it still is slow at recharging. I didn't really have many programs anyway, a few simple card games, crossword puzzles and some weather apps. Right now, I think I have maybe 4 simple apps on the tablet and it is still not charging when on. I checked the battery status in settings and it says "not charging". However, if I turn it off and then plug it in, a red battery indicator shows it as charging."
