My lg 42ls3450 is giving black and white pictures without sound and colors. how to fix it.
where as i bought it from canada and brought to Pakistan,but it is not giving colors and voice,just giving black and white pictures.
kindly anybody let me know how to get colors and voice
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
Obtain your owner's manual and follow the connection steps exactly. It's possible you have made the connection at the Internet point.
If this wasn't the problem refer to the trouble shoot section and
follow the steps indicated.
Having the same problem. Can't connect the soundbar via HDMI as the LG 42LS3450 does not support Audio Return Channel over HDMI. Which means I'm only left with optical cable, but the TV doesn't seem to have that either!
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
s-video carries luminance and chromanance.
In simple terms, luma provides a a black and white picture, chroma the color data.
without chroma, you get no color.
Either
- the cable is bad (usually in the form of bent/broken pins in the connector ends
- the source device is bad
- the projector input is bad
