Question about Raco "ACE" TOGGLE "KILL" SWITCH 3A/250VAC
A kill switch for 49cc - Raco "ACE" TOGGLE "KILL" SWITCH 3A/250VAC
    Sergeant:
  • 351 Answers
What's the question? How does it work? It is probably a momentary switch that is normally in the RUN position, you hold the lever in OFF position until motor stops then release it and it springs back to RUN position..
Posted on Feb 16, 2015
6ya staff
SOURCE:
Tourke settings moto 200
Exhaust manifold nuts 10-14Nm
Exhaust mounting bolts 30-14Nm
Engine mounting nuts 45-50Nm
Oil drain bolt 11-15Nm
Oil filter screen cap 10-20 Nm
Spark plug 10 -14Nm
Crank case bolts 8-12Nm
Cylinder head bolts / nuts 18Nm-22Nm
Variator center nut 35-40 Nm 49cc gy6 149cc gy6 40-60NM
Clutch assembly nut for spring 50-60Nm 49cc gy6
Clutch center nut 35-40Nm 49cc gy6 1 49cc gy6 40-60NM
Gear box drain and fill bolt 9-15Nm 49cc -149cc gy6
Fan bolts 9Nm 49cc -149cc gy6
Valve lash adjusting nut 7 Ft Lbs
Standard Torque Setings
M5-Bolt or Nut--5Nm
M6-Bolt or Nut--10Nm
M8Bolt or Nut--21.5Nm
M10Bolt or Nut 35Nm
M12Bolt or Nut 55Mm
M6Bolt or Nut flanged head 12Mn
M8Bolt or Nut flanged head 27Nm
M10Bolt or Nut flanged head 40Nm
Jan 13, 2018 | Cell Phones
49cc Mini Chopper wiring diagram @
Hi, Ellis for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
49cc Mini Chopper wiring diagram Google Search
49cc wiring diagram
Mini Chopper Wiring Schematics Wiring Automotive Wiring Diagram
Wiring Diagram For 49cc Mini Chopper Find And Save Wallpapers
http://4thdimension.org/gallery/2-stroke-49cc-mini-chopper-wiring-diagram.html
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 31, 2017 | Motorcycles
How do I find a wire diagram for a 4949cc mini choppers ga-643f
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.
http://www.tootoo.com/idetail/49cc-mini-chopper-with-two-strokes-ga-643f_24495635_721073_6878978_16262765
49cc mini chopper wiring diagram Google Search
Download 49cc mini chopper wiring diagram
APC Mini Chopper Key Switch
Dec 15, 2015 | Motorcycles
My 49cc quad bike is new wont start have changed the coil and plug but no spark tried diconnecting the kill switch
Maybe re-check the gap between the coil and the flywheel? x2 business cards is a good gap for those.
May 12, 2010 | RTO Mini Quads
How to start 49cc, 2 stroke mini Harley motorcycle
hi i have just brought a mini harley 49cc bike
in red and black and dont have all the light the kill switch wire has been cut and on the brake leves not the brake wires have been cut for the lights or something there is no battrey on it ent got a key
how could i get it started
Mar 09, 2010 | RTO Mini Quads
49cc mini pocket quad wont start
if it has a kill switch make sure it is on, check that you are getting spark at the plug and have the right fuel in the motor.
Remove the air filter from the carbi and squirt some 2 stroke fuel directly into the throat of the carbi and try to start it.
hope this helps
May 19, 2009 | RTO Mini Quads
49cc 2 stroke runs for 20 sec. then cuts out
20 seconds is all that is required to drain the float bowl. You have a float bowl/needle valve problem.
Apr 24, 2009 | Fender 2 Stroke Full 49cc ATV # ATG-47B...
Raco "ACE" TOGGLE "KILL" SWITCH 3A/250VAC Logo
107 people viewed this question
Top Raco Electrical Supplies Experts
Gene Haynes
john h
Are you a Raco Electrical Supply Expert? Answer questions, earn points and help others
