Fixing Film Unit engagement / disengagement error..
Remedy
Possible cause is overload or rotation failure of the motor due to an electrical trouble 1. Check if the Fixing Assembly is installed. 2. Remove and reinstall the Fixing Assembly 3. Check the gear 4. Replace the Fixing Assembly 5. Check the harness/connector between the DC Controller PCB (UN09/ J210) and the Fixing Motor (M17). 6. Check the harness/connector between the DC Controller PCB (UN09/ J12) and the Fixing Pressure Release Sensor (PS24) 6. Check conduction of FU1153 in the AC Driver PCB (UN14) => Replace the AC Driver PCB (UN14) in the case of disconnection. 7. Replace the Fixing Motor (M17) 8. Replace the DC Controller PCB (UN09)
This error is related to the fixing film engagement/disengagement, the black gear on the end which is also a sensor flag sometimes break, this usually requires a complete new fixing unit
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Go into settings and scroll down, then click reset. You can manually reset it by replacing the sim card or pressing the button inside of the area wher the sim card is.
Hello, I would recomend You the two second hend refurbished iR 3300 Copier ( B&W ) or Ricoh AF 1045/2045 and color clc 3200 for color, for the beginning and if you want later take stronger 50ppm i.e. IR advance 6055 for B&W and IR ADVANCE C2030L.
