Tv model is UE32ES6710 The hifi is an old, 1990, Kenwood and it has no usb port. I've attached two cables into the tv audio connections and the other ends to the hifi amplifier auxiliary input. Result - no sound
It doesn't lokk like your TV has an analog out for your Kenwood system. It might have an optical out but unless the Kenwood has optical in then you'll need to upgrade to a Home theater system with HDMI.
Testimonial: "Yes, you're correct I'm sure now.I was trying to use the audio in sockets (!!). There's no optical connect on the old amplifier. I shall give the headphone socket a go, via the amplifier or directly connected to the speakers. A last gasp! Many thanks for your help John"
SOURCE: Connection help with receiver and lcd TV
depend on what you wants to do. if you wan to get sound from your tv on receiver connect out from tv to in on receiver if U have optical out from tv send this to optical input on your receiver and set up your receiver to impute to digital HDMI carrie sound and video...
(My Denon receiver set-up shows an HDMI cable going from the Video Out on the TV to the HDMI MONITOR OUT on the receiver)
OUT TO OUT don't make sense ...could be out to impute you may have HDMI going from receiver to TV and other HDMI imputs on receiver to use receiver as distribution unit say you have satellite HDMI, DVD HDMI, Computers HDMI IMPUTE all of this connected to your Receiver and the HDMI monitor out from your receiver connected to TV so now you may select any of this sources to wach In your TV and lessen trough receiver speakers
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
SOURCE: DVI-->HDMI cable causes tv speakers to hiss and pop
DVi to HDMI. ? hmmmmm
I recon you spend £49.99 and get a DVI & Audio to HDMI Converter. This will resolve the issue
SOURCE: No sound from external speakers system
Look into your monitor settings and computer settings and see if you can reverse the "input" and "output". If both are set to line in or line out then they pretty much cancell themselves out.
SOURCE: My Sharp Flat Screen Tv Model LC32SB24U has a USB
The USB entry is mostly used for a foto slide show.
Please read the owners manual before plugging in any kind of USB sticks or other cable's in a TV set.
It can damage the set when there is a ground connection between some devices.
