2003 Nissan Sentra GXE Logo
Danny kennedy Posted on Feb 03, 2015
2003 nissan sentra gxe cranks then dies everytime wont stay running what is wrong
Peter Bruecken
Level 1:
New Friend:
  • Contributor 19 Answers
  • Posted on Feb 03, 2015
Peter Bruecken
Contributor
Level 1:
New Friend:
Answers
19
Questions
5
Helped
16788
Points
39
If the car has a chip key, the ignition may not recognize the key. Try another key or read the trouble code and the chip reader may not be working.
  • Danny kennedy Feb 03, 2015
    It don't have put 1 key can't be that is it fuel pump ?
5 Related Answers
Anonymous
  • 962 Answers
  • Posted on Nov 10, 2008
SOURCE: 2002 NISSAN SENTRA GXE 1.8 POOR IDLE LACKS POWER IDLE FLUCTUATES BETWEEN 1800 TO 1100 RPM
Check for vaccume leaks and also you PCV valve. check the hose too. Visually inspect every vaccume hose you can find. Sounds like a leak .
Anonymous
  • 6784 Answers
  • Posted on Mar 20, 2009
SOURCE: 2003 nissan sentra gxe trouble shifting into 2nd
Hi. The Nissan has been known to have issues with the stock solenoids that are installed by the factory. The transmission also has a OD shift solenoid as well. I would do two things. ONe, check the fluid level if you can. It shouldn't be caped with a plug but, some models have sealed transmissions. If your model has a dip stick, please check the level of the transmission fluid. If the level is ok, i would drop the pan and check the solenoids to make sure that they are working properly. while the pan is dropped, It will be good to visually inspect the bottom of the pan for metal fragments and discolored fluid.If you see anything not normal like black fluid or metal small fragments, this will not be normal. Although, the shift patterns of this model are quite unusual, I would recommend using the instructions above to make sure that this transmission is not malfunctioning.
please rate and have a great weekend..
Anonymous
  • Posted on Mar 23, 2009
SOURCE: 2003 Nissan Sentra Problem overheating and heater doesn't work.
I had this exact problem a few weeks ago. The repair shop first changed the thermostat. Didn't fix the problem. Next step, they found the radiator was clogged. They replaced the radiator and now everything works fine.
Anonymous
  • Posted on Apr 24, 2009
SOURCE: 1999 nissan sentra gxe headlight problem
I switched one of the new bulbs with a working older bulb, and the problem went away. weird...
Colin
  • 1584 Answers
  • Posted on Jan 26, 2010
SOURCE: i need to find timing marks for a 1.8 liter nissan
Located on the lower crankshaft housing, visible from the top though with a timing light.
2003 nissan sentra gxe cranks then dies everytime wont stay running what is wrong ?
The car may not recognized its key. I would try another key or see if there is a code for an unauthorized key.
Sentra that will Not start
If it cranks smooth as you say there may be no compression in which case the timing belt is broken! Not good.
1helpful
2answers
I have a 2003 Nissan Sentra GXE 1.8l. Yesterday when I would start it up, it would crank for about 5-10 seconds before it would start. This morning it just kept cranking and wouldn't start. After a while I...
I have the same problem with my 2003 nissan sentra gxe. I don't know about under the hood, but I was told that the gas filter needed to be changed. Something's wrong with the gas intake to the engine. I had it "fixed" but it still does it a little bit everytime.
2001 Nissan Sentra cranks but wont start. Put a
good day Sir, try to check the spark plugs and air filter, i hope this tips will help you.
2helpful
2002 Nissan Sentra Loses Power
SERVICE IT .....OIL PLUGS, AIR ,FUEL AND OIL FILTERS GET TROTTLE SENCOR AND THE MASS AIR FLOW SENCOR CHECKED
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
