How can I connect this EQ on my mustang I don't have amplifier right now only the EQ
    New Friend:
  • 15 Answers
An eq is kind of like an amplifier anyway it boost the sound and tailors the sound to your taste. Your eq should have a wiring diagram on the bottom or top of the unit. Your factory radio should have a wiring diagram on top or bottom of it as well. So all you have to do is match left + to left + and right + to right + etc. It's really easier than you think. You just have to pay close attention to the diagrams.
Posted on Feb 03, 2015
2 Suggested Answers
6ya staff
SOURCE:
Miss Raye
SOURCE: Ftx-2001 Ashley amplifier with XR-1two
The XR-1 is a 2 way crossover. Depending on the resistor networks, it can be anywhere from 50hz to 5khz. If the packs are marked 153, It's 750HZ, if they're 103 it's 1.2khz if 104 it's around 120hz and 154, 80 hz.
The hi side amp is ch1 the low side is ch2 The amp can be configured as a subwoofer bridged amp , a subwoofer with full range dual ch. You can't make it into a stereo amp with out the obsolete stereo input pack that replaces the XR-1 crossover
Posted on Oct 26, 2011
Im trying to hook up a eq to my yamaha c80 preamp and dont have preamp out puts how do I go about doing it?
Hello Tom. The preamp outputs are on the right hand side of the back panel. You have normal and inverted outputs. These are RCA connections and should be connected to the inputs of an EQ unit. The outputs from the EQ unit are then connected to the input of your amplifier (c65) Perhaps I am misunderstanding youtr question? If I have not answered helpfully, feel free to ask further questions.
Cheers, Don.
Jul 07, 2014 | Yamaha Audio Players & Recorders
Bose 901 equilizer connections to sansui G901DB
It sounds like you may have only the 901 loudspeakers, and not also the companion 901 equalizer box. You must install the 901 equalizer properly--using the tape monitor loop of the G901 receiver. If you of not, the 901 loudspeakers will perform poorly.
Jun 17, 2014 | Bose 901 VI Main / Stereo Speaker
Ftx-2001 Ashley amplifier with XR-1two way crossover. I am trying to connect from my EQ (2-1/4 jacks) into my amplifier, do I connect mt left & right out of my EQ into the balanced input XLR. Not an...
Dec 28, 2010 | Ashly FTX-2001 Amplifier
I would like to hook-up amp to graphic equalizer i would like picture if possible.
An EQ (equalizer) is generally connected between the low level output of a device (phono, CD, DVD, etc.,) and the amplifier's input. If you choose to place the EQ at this point, only the device connected will be equalized. All the other sources will be unaltered.
A more complete way is as follows:
Some amplifiers have a jacks labeled Left & Right "PRE OUT" and Left & Right "AMP IN" with a heavy gauge wire or strap that connects the left AMP IN & left PRE OUT together; and the right AMP IN and right PRE OUT together. Removal of the wire or strap will cause the amp to fall silent, as the low level signal no longer has a path from the PRE OUT to the AMP IN jacks. If you were to insert the EQ here, the path would be restored - but allowing you to boost or cut the level of certain frequencies BEFORE they are amplified. This is accomplished by connecting PRE OUT to EQ IN and EQ OUT to AMP IN for both the left and right channels.
As I mentioned, only some amps have these PRE OUT and AMP IN jacks - many however do not. In this case, you may be able to use the TAPE MON jacks. The TAPE MON is the Tape Monitor and appears on most "half-way decent" receivers. These jacks were provided to enable listening to a tape in nearly "real time" as it was being recorded on higher end "3 head" tape recorders. If you don't have a "3 head" tape deck (most do not), you can use these jacks the same as the PRE OUT and AMP IN jacks above. This is accomplished by connecting the TAPE OUT to EQ IN and the EQ OUT to the TAPE IN for both the left and right jacks. You would then select the source of the music - be it CD, Phono, etc. and with the EQ powered, pressing the TAPE MON button on the receiver, you could hear the difference between the EQ in the circuit and the EQ out of the circuit.
The key in the examples above is that there is always an input connected to an output. Don't connect inputs to inputs and outputs to outputs. Take your time and work one cable at a time - one end to an input and the other to the corresponding output.
Some situations may arise if using Dolby Digital, THX, etc. type input signals. Sometimes it is not possible to equalize them. If you have sources (DVD, Satellite Receivers, etc.) that have an optical or coaxial connection, those will be the ones that may have undesired affects. The familiar RCA type jacks for left and right signals should work perfectly.
I'll see if I can find a link with a picture...
Sep 29, 2009 | Audio Players & Recorders
I have a numark cd1 combo and i need to connect it my preamp and
1-RCA outs on the cd1, right? Route to ins on the preamp (use adapters if necessary, you don't say what pre and eq you have)
2- if the pre has an effect loop/aux bus or whatever, install the eq in the loop, and output the pre to the ins on the power amp; otherwise route the outs from the pre through the ins on eq then to power amp ins.
Jul 01, 2009 | Audio Players & Recorders
Need help connecting my eq to my system.
You will want to connect all of your devices to the pre-amp or receiver, then connect the outputs of your pre-amp/receiver to the inputs of the EQ. Then connect the outputs of the EQ to the inputs on the amplifier or receiver. If you give me some model numbers, I would be able to tell you exactly which cables go where.
Mar 31, 2009 | Audio Players & Recorders
BOSE 901V WITH EQ PIONEER XSV -95 RECIEVER.
Turn down the second amplifier (which the speakers are connected to). This hum is the amplified 'noise' from the EQ and/or amplifier. Try using a much higher graded second amp (eq 500w)
Mar 21, 2009 | Bose 901 VI Main / Stereo Speaker
How to connect the FISHER EQ-273 equalizer to the FISHER CA-885
It goes between whatever you are using to create the sound and the input to the amplifier.
e.g. for a standard HiFi.. HiFi aux out to equalizer input... equalizer output to amplifier aux input.
Trying to keep left and right channels the same through out. They are usually colour coded. Red = right Left = white.
Hope that helps.
We all start somewhere
Mar 18, 2009 | Audio Players & Recorders
How to connect a sr430qx equalizer to abpm500 gemina mixer and a carvin dcm2000
All of three of these components have balanced connections. There are many different ways to connect- but this is the best option. You will need 4 x standard XLR3(cannon) mic leads. Starting from the Gemini mixer:
take the left output and plug it into channel 1(A) of the DOD EQ
take the right output and plug it into channel 2(B) of the DOD EQ
then...
Connect the EQ output of channel 1(A) to the input 1(A) of your Carvin amplifier
Connect the EQ output of channel 2(B) to the input of 2(B) of your Carvin Amplifier
Happy DJ'ing
Rus.
Feb 19, 2009 | Dual Audio Players & Recorders
Connection
There are 2 ways to have an EQ in the system. If the mixer (1204) has inserts for the mains, you can use a set of insert cables to connect the EQ. If not, connect the Output of the mixer to the Input of the EQ and the Output of the EQ to the Input of the Amp.
The insert cables will allow you to electrically connect the EQ as described above only using a single set of cables. These cables are 1/4" balanced or stereo at one end (Tip-Ring-Sleeve) and dual XLR at the other. You will need 2 insert cables, one for right and one for left.
Hope this helps,
dan
Jun 19, 2008 | Audio Players & Recorders
88 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
