Ge has had a long time issue with their control boards failing and usually loses the low voltage side. I am assuming that it is not cooling at all? Do the lights inside flash as well? What happens if you try and get water? Does everything stop momentarily?
When you plug it in listen toward the lower back of the unit. As it beeps, listen for an accompanying clicking coming from the back. That is a telltale sign that the board is having an issue.
A visual inspection will sometimes show a problem whether it be a burn mark,maybe a swollen cap or sometimes it looks completely normal.
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
*if the DSL light on your modem is blinking..
TRY: using different filters// check physical connection
IF: not resolved call ISP for a trouble ticket for their line department
*if all the lights constantly blinks
DO: purchase new modem, maybe deffective already or check if modem still under warranty so provider can replace it
NOTE: plug 4100 modem directly to the back of the computer tower without the linksys router and check if light status still the same...
HOW: cable connected from back of modem shud be plug in directly to port at the back of PC tower.. completly remove linksys and turn linksys off..
Unplug the power cable... Hold the power button down for 15-20 seconds... Plug cable back in and check for light... If this still didnt work, then unplug cable again, take battery out, wait 10 seconds.... Put battery back in, plug cable back in and this should allow you to boot...
Each telephone must be connected to line 1 and line 2 for proper operation. The remaining lines 3 and 4 may — or may not — be
connected to each station as you desire. First plug in the battery,
then the phone lines (1 & 2 are mandatory), and third the power
cord. If your intercome LED is blinking red and green, then press:
STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e.,
any of the memory buttons 1 through 16 not already assigned to another
telephone set). Then wait for the phone to go through its initiation
sequence during which it searches each of the four possible lines.
After that concludes, you should get dial tone on your active lines.
:-) Marco
