SOURCE: Consew Industrial Machine 2270 stitch length dial not working
Sounds like it is either out of time or the adjuster spring needs to be replaced.
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
SOURCE: I bought a second hand Juki industrial machine ,
upper tension sets the lower thread tension (upper thread is what you see on the underside of the fabric). Bobbin tension is for the thread you see on the top of the fabric
SOURCE: i have a juki industrial machine when i try to
so many different versions to disengage the drive, but all are located on the right hand side of the machine on the part that allows you to rotate the sewing mechanism by hand. there is likely a button or that part will pull outwards
Testimonial: "thank you so much there is not a button so it must pull out i will try it tomorrow"
SOURCE: My Juki industrial machine will
hi there
can you please tell me your machine model? i can help
any way if lockstitch machine you must first make sure you installed needle correct way and you are use new needle
can you check hight od needle bar is ok if you move it up and dwon?
can you check timing between needle and tip point for hook?
i can send page from instruction manual how to adjust hight of needle bar and timing with hook.
best regards
ashraf abozid
[email protected]
