Cleaned filter new plug increased idle speed increased high and low needles but machine starts idles ok until i attempt to increase speed and then dies.
There is a Spark Arrester/Exhaust Screen on the muffler that is most likely clogged with carbon. You can remove most of them and either burn off or clean out the carbon built up. It can’t exhaust which prevents the engine from running above idle
May I suggest checking along the fuel line and its attachments for a very minor air leak. The minute it sucks air it will stop. Check any rubber washers or O rings too.
Have you changed the fuel filter? The carb may need to be cleaned and rebuilt too. Sometimes you can buy a new one for about the same price as the kit.
