LG smart TV turns on to white screen with code 03.23.32.01
Turned on TV with direct tv remote to get above code
Have tried using LG remote to turn off TV & turned direct tv remote on & off several times & screen does not change
Have turned function between direct tv & tv several times
Tv won't turn off although direct tv does
Here are the steps to program your OneForAll URC 3050B00 remote to control your LG smart TV:
Turn on your LG smart TV. Press and hold the "TV" button on your OneForAll remote until the LED light on the remote turns on and stays on. Enter the 4-digit code for LG TVs. The most common codes for LG TVs are 0030, 0056, 0178, 1265, and 1398, but you can also find a complete list of codes on the OneForAll website or in the manual that came with your remote. Press the "Power" button on the OneForAll remote. If the TV turns off, the code has been successfully entered. If the TV does not turn off, repeat steps 2-4 with a different code until you find the correct one. If none of the codes work, you can also try the code search function on your OneForAll remote to automatically find the correct code:
Turn on your LG smart TV. Press and hold the "TV" button on your OneForAll remote until the LED light on the remote turns on and stays on. Press and hold the "SET" button on the remote until the LED light blinks twice. Press the "9" button on the remote. The LED light should blink twice again. Point the remote at your TV and press the "Power" button repeatedly until the TV turns off. Press the "OK" button on the OneForAll remote to save the code. I hope this helps you program your OneForAll remote to control your LG smart TV!
Hi
The following codes should work with your model
12293,13382 ,10178 ,10000 ,11034
Setup Instructions
Turn on the TV manually or using the original TV remote.
Press and hold the "Mute" button and the "Select" button on the direct tv remote at the same time until the green light on the top of the remote blinks twice.
Using the number key, enter the first digit of the code above. Wait for the green light on top of the remote to flash twice
Enter the remaining 4 digits of the code as above.
Aim the remote at your TV and press the "OFF" key once. Your TV should turn off. If it does not turn off, repeat the steps above, trying each code until you find the correct code. www.electro-medical.blogspot.com
i wanted to program lg plasma smart tv remote with samsung blu ray,was so easy! with tv on conect blu ray hdmi to tv and press simplelink button on remote, and automaticly turns blu ray on.... thats all !!!! u can use only remote when watching movies...
Press MENU on remote. Select "Parental, Favs and Setup". Select "System Setup". Select "Remote". Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control. Make sure your TV is turned on. Slide the mode switch at top of remote to "TV". Press and hold the MUTE button. This is located above the number 1 button. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice. Enter the first TV code you have. The green light on remote should flash twice. Aim remote at TV and press PWR button once. The TV should power off. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
Make sure your TV is turned on. Slide the mode switch at top of remote to "TV". Press and hold the MUTE button. This is located above the number 1 button. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice. Then enter 9911, the green light on remote should flash twice. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off. When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
My TV does this too. i know how to remove the white screen but the top will still have power only vo4.52.00 to get rid of the white screen press 'return' on your TV remote (not direct tv remote) then change the input pack to whatever it is it needs to be on to watch your (whatever)
