Question edited for a lot more clarity.
Question moved from Cars and Trucks to Make model category.
Is it tripping the breaker? If so it is likely an issue with the motors or the controller.
Circuit Breaker (Reset Button)
Your scooter is fitted with the latest in electronic controls that are programmed to protect
the electrical system from abnormal overloads. Provided for extra protection is a circuit
breaker, located on the battery pack. Should there be a situation where your scooter stops
for no apparent reason, please check that the circuit breaker has not popped.
NOTE: To preserve battery charge, your scooter may go into sleep mode after being idle for
a few minutes. To remove from sleep mode, turn the scooter switch off and back on again.
Check List
If your scooter fails to operate, please check the following:
ā¢ Unit is switched on.
ā¢ Drive/Freewheel mechanism is in the drive position.
ā¢ All plugs and connectors are clean and firmly connected.
ā¢ Battery level shows full charge.
If the free wheel device has been operated with the scooter switched on, then the scooter
will not operate until the ignition key has been switched off and then on again.
Please consult your dealer if your scooter does not run after checking these points.
Manual
https://www.manualslib.com/manual/461818/Shoprider-Echo-3-Sl73.html?page=14
More here
https://www.google.com/search?q=shoprider+echo+3+clicks+breaker+troubleshooting
