Usually it needs water but the reservoir is full
1. Water level is too low.
2. No T-DISC in machine.
3. T-DISC is damaged.
4. Machine not prepared for use.
5. Internal machine fault.
The float that detects the water level might need freeing up.
Or, assuming detachable water container, ensure that it is seated fully. Lift it up a bit and guide it down firmly.
If it's not that, try unplugging the machine for about 5 mins. and see if it resets to normal operation.
Or, assuming detachable reservoir, ensure that it is seated fully. Lift it up a bit and guide it down firmly.
I've done all of the above and still not brewing.
Same here flashing 4 lights just taunting me. Landfill. So frustrating. Going back to a manual plastic cone and filter and making my pour overs.
SOURCE: manual for Braun Tassimo TA1400 CoffeeMaker.
I found a website under Braun that had the operating manual in pdf.
SOURCE: Braun Tassimo Coffee maker quit working
Hmm if not in covered try
http://rapidshare.com/files/238159116/Braun_Tassimo_3107_Disassembly.pdf.html?killcode=397312781122638452
SOURCE: lights keep flashing on my tassimo machine
if your lights are flashing on your mashine just keep your finger on the button untill its filter threw, willtake up to 2 mins. simon bernasconi
SOURCE: All the lights are flashing on my Braun Tassimo
Several possibilities:
(1) No water in tank.
(2) Tank not inserted properly. Try removing tank and then replacing it, making sure that the hook-tab at the back of the tassimo body engages the matching slot at the front of the tank.
(3) Tank not seated properly. Try pressing down on the tank and twisting left or right. If this stops the blinking and allows your drink to brew, at least you know where the problem is. If you have to do this all the time, consider exchanging the unit.
(4) The lights will all also blink if there is residue (coffee, milk, etc) on the bar code reader window. The residue is usually plainly visible. The bar code reader window is a horizontal rectangel directly under where the bar code of the T-Disc sits in the Tassimo. To fix this, just wipe the window clean (no need to scrub), close the lid again and check for blinking.
