Model 2000fs
SOURCE: When moving at top speed, my scooter hesitates at
hi, that is a textbook problem related to the speed controller pot,
the pot is attached to the lever you move to go forward etc,
to be 100% certain trying moving the lever in the upwards direction while gong forward ? does it speed up ,a new speed pot required.
Regards
GeWiz.
SOURCE: I have a Go Go scooter that is an older model. It
Hi, That sounds like the speed pot is faulty,
When going along push the lever in the upwards direction as well as forward , does it speed up ? does it response ? if so then that's the problem.
There could be a issue with the metal key making a good contact when inserted.
Regards
GeWiz.
SOURCE: I have a pride scooter that will not run at top
hi, first check the speed throttle by moving it in the upwards direction while the speed control is turned fully on, if there is a response to moving the speed pot in up and down direction , you founf the fault, otherwise the speed control is at fault, if thats proves to be okay then its the controller breaking down , check the brushes on the motor.
regards
GeWiz
SOURCE: speed control(little knob on panel) move it a
part needs replacing
ted mobility centre penge 0208 676 0944
SOURCE: scooter runs then stops I turn offf the key and
the batteries are worn and problably need replaced , the computer will stop running the scooter at threshold voltage, older batteries and will hit this threshold voltage and slow the scooter
