I'm using Exchange 2010 on a Windows 2010 server. This is the fourth time my database has gone corrupt since December. After the db is replaced or repaired everything is fine for a month or two and then the db is corrupt again. Has anyone else experienced this issue? I don't need any help with recovery(I could do it in my sleep at this point), just to figure out what is causing the corruption. I've checked my AV software and all the correct files and folders are excluded from scans. No hardware errors. Information Store (248) First Storage Group: A bad page link (error -338) has been detected in a B-Tree (ObjectId: 24793, PgnoRoot: 943649) of database D:\Exchsrvr\MDBDATA\priv1.edb (943649 => 1205152, 1272360). The only strange thing I've noticed is that two times I've had users who had an e-mail which can't be deleted. The only way I've been able to delete the e-mail is to transfer to a pst and then delete the mailbox and re-add it. Any help would be appreciated.
If you keep getting corruption, the most likely cause is bad hardware.
Hardware problems are probably responsible for 99% of all corruption issues.
Have you checked all of your hardware to make sure that it isn't the
culprit? As Teo suggested, have you ensured that you have the latest
firmware and drivers for all components? Does your server have a RAID
controller? If so, is it battery backed? If not, do you have write-caching
enabled? Suspect hardware here could be any one of hard drives, controller,
backplane, memory, etc. If it is a brand name server, make sure that you
get the latest diagnostics and run all tests on it.
If that doesn't get you anywhere, your best bet would be to open a case with
PSS - they should be able to help you identify what the cause of the
corruption is. The following KB article may also help you to find the
cause.Try this EDB Open File Tool http://www.edb.openfiletool.com/
Kernel for exchange edb repair software easily fix database corruption issue. With the help of this software you can convert edb to pst format and repair edb files. For more help visit http://www.convert.edbtopstfile.net/ or
http://www.exchangeserver.recoveryfiles.org/
Excellent EDB to PST converter software which is an outstanding method to convert Exchange mailbox to PST. It let you to recover Exchange EDB file and export EDB to PST along with entire emails meta-data-To, bcc, cc, subject, date and time etc. This software works brilliantly to repair corrupt EDB files and successfully open EDB to PST. It works on all Exchange EDB file version on 5.0 to 2016.
Read More :- EDB to PST Converter
Don't get worried due to corrupted or damaged Exchange server database. Just try Exchange Server Recovery Software which is one of the most preferred Exchange recovery Tool in these days. - See more at: https://softcart.wordpress.com/edb-to-pst-converter/
You can go to this link where same topic have discussed.
Fix corrupt messages exchange 2010 mailbox
You can request for mailbox repair using PowerShell command. But before going for any solution don't forget to take backup of Exchange Database (EDB file) first.
