Look for a bad rectifier bridge or shorted out diode.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john_32f4b76dad4781c4
SOURCE: monitor fuse keeps blowing
There is definately a shorted component that causes the fuse to blow. Nomaly the ceremic capacitors are the cause of the problem. Check to see if there is visiual dark or burnt ceremic caps with label sameting like this "SCK 083" near the fuse area and change it. Hope it helps,cheers.
SOURCE: ACER AL 1912 19'" LCD MONITOR
I have the service guide for this monitor and the values for the R811 to R814 are the same: 1.8 . The mosfet is a 2SK2645. I will like to send the pdf file, but I new in this site and I don´t know how to attach a file due the only options that I see is a link, image or you tube clip.
Good luck
SOURCE: BenQ FP72G+ 17" LCD Monitor NO DISPLAY
There is a small thing that make it work again, search on the board to BFXXX fuse usually its a 3 Ahm fuse replace it and it will work.
SOURCE: I have a similar problem to one posted a few
Look real close at the solder joints on the inverter transformer pins, and the transitors. What usually happen is that the cold solder joints will mess up the bias on the transistors or causes arcing and that will take out the transistors, you need good magnifier glass to see, you will see ring/cracking around the component's leads.
http://s807.photobucket.com/albums/yy352/budm/Poor%20solder%20joints/
It will get to the point that the transistors 2sc5707/5706, and also still should look for bad caps.
Replacement board: http://www.lcdrepair.us
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
SOURCE: Fuse Blowing in Power Supply SOYO MT-GW-DYLM24D6 24
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
BSFP2415004A5 Soyo CGCPOM24EI4 Power Supply for MT GW DYLM24D6
