Computers & Internet Logo
N
Norma Doyle Posted on Jan 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turned of my laptop yesterday. now it wont turn back on, all I get is a black screen and the white arrow can anyone tell me how to get it to work again
Try turning it of again and turning it back on. pressed the windows button -c also windows-w a couple of times the Acer logo comes on for a second or two then goes back to the blank screen with the little arrow but cant get anything else
Penzance Computers
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Acer Master 2,003 Answers
  • Posted on Jan 30, 2015
Penzance Computers
Acer Master
Level 3:
Renaissance:
Answers
2003
Questions
0
Helped
337849
Points
7859
Your laptop HAS turned back on.
One thing that is a problem is that the operating system hasn't finished loading.
You may need to use the recovery routine, or the hard disk could be dying.
Help, my dstv doesn't work since yesterday afternoon. The screen is black and there is no sound. Tried to reboot but doesn't work. Anyone who can help?
Try rebooting with your main modem. Just turn the modem off, count to 10 and then turn it back on again. You might also call the tech line for your service provider for advice.
Rca tablet model rct6272w23 screen pixalted white then went black now wont turn on
I would recommend calling RCA support at (800) 252- 6123 so they can suggest some troubleshooting steps you can take. If it is still under warranty and you're unable to get it working then you can send it back and get a replacement
When I power on my computer my monitor screen goes a solid whitish gray. worked fine yesterday, and then today nothing.
Laptop LCD screen turned completely white
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out which one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen and the inverter board. After that you connect another working screen and test video.
The original screen is white but my test screen works normal and I can see the image. After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it’s still white.
CONCLUSION.
In my case this problem is related to the LCD screen and it has to be replaced.
Cant use my phone at all
If it is a slide phone then the problem would be in the connector of the slide. If its not a slide then you need to replace the glass IC (Keypad IC) of the cell phone.
Dec 11, 2009 • Cell Phones
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
2answers
My everex stepnote wont turn on, fan runs but it wont boot
I have a Everex StepNote Laptop VA4101M. Model Number VA250W. I can turn the power on the laptop but the screen is black. I have already try taking the battery out and the power cord out and nothing.WHAT DO I DO?!?
Dell Inspiron 6400 PC Notebook shows black screen after startup
I have a Inspiron 530 when I turn on it you can see that everything start ok but before I type my password everyting turn black an the only you can see is the litlle white arrow of the computer mouse
3answers
HCT HDVR960S now only shows black and white panels on TV
sgtken,
I also purchased the same unit. Please let me know if you figure out how to get the unit back to factory settings. I checked over the unit and do not see a reset button. Thanks!
Bill
[email protected]
2answers
HCT DVD recorder: HDVR-960s
I purchased this same unit yesterday from the PX Power Zone. I hooked up the unit and even managed to record a few minutes of a show. I then went into setup and made a few changes. Now, I have no display at all from the unit. Does anyone know how to reset the unit back to factory settings? Please email me at [email protected]. Many thanks!
Bill
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
