Fuel pumps outside the gas tank have nothing to do with fuel gauge readings. There is a fuel level sender unit inside the tank with a float which supplys variable ground circuit to the gauge. If you can find the wire to this unit, you can ground it to see if the gauge now goes to full. If so, sender unit in tank is bad, or has bad wiring/ground.
