Samsung LN46A650 46 in. LCD HDTV Logo
A
Anita Petry Posted on Jan 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to correct Samsung tv to internet
Correct Samsung tv to wireless router
zeceten
Level 2:
Sergeant:
  • Expert 399 Answers
  • Posted on Jan 30, 2015
zeceten
Expert
Level 2:
Sergeant:
Answers
399
Questions
0
Helped
108486
Points
675
I do not believe you can connect the TV to the wireless router right out of the box. You need to buy extra equipment in this case, the Samsung Digital Media Adapter. Global Download Center
Hello My Samsung tv is not connecting to the internet via WiFi. It has no IP address on the tv . Can the WiFi mode be defective Errol
Well... Yes and No... Does this set have an Ethernet port?
If so then try and plug it in that way.
Try and reset the router and tv
Make sure the connection settings are correct or defaulted
Are you entering the correct password?
Are you close enough to the router?
reset the network setting on the tv
it's possible you may have a bad wifi chip but im not thinking you do. Good Luck and come back it the above does not help we can go more into detail.
Mr.Mike
My tv picks up my wireless internet signal but won't connect. Says "connect fail"
Have you entered the correct passcode / passkey this information is usually located on the bottom of your wireless router
Cannot wireless connect Samsung DVD Blue Ray to Net Flix
set the ip address to be detected automatically in the tv network settings.
What you need to know is the encryption key used on the Wi Fi
If you do not know it it might be on the case of the Wi Fi access point device.
Otherwise you will need to log into the router by typing the router's ip address into an internet browser on the working computer.
Using wireless laptop for internet connection toNetflix on TV while traveling instead of desktop router at home and the SSID is not accepted--error 51032. How can I get a different access SSID? Also, on...
When you use your wireless-enabled computer far outside the range of your wireless-enabled router, you definitely will be trying to connect to a different wireless-enabled router.
That "foreign" router will broadcast a different SSID than your router is broadcasting.
Use "View Available Wireless Networks" to find that SSID, and "connect" to it.
> all of my options are ...
Correct.
How do I link my Linksys wireless router to my Samsung tv so I can have internet on my tv or is this possible?
check your Samsung manual it will show exactly how to set your Tv to the router.
http://www.usersmanualguide.com/samsung/tv__lcd/la15s51b
My computer has internet connection through the port on the back, but not through the router for wireless networking. All the connections from the modem to the router and further to the computer are...
So, just to confirm:
PC via ethernet has internet connection OK?
The router IP is 192.168.1.1
The PC ethernet IP is 192.168.1.n (n is not 1)
If you unplug the ethernet cable, you no longer have a connection.
If these are correct, did you previously have wireless internet working? If so, just reboot the router (unplug its power).
If not, you'll need to check the wireless settings in the router with those of your wireless network card, making sure you are using matching security settings (WPA-PSK, AES256, matching 'key').
To access the router, browse to http://192.168.1.1 (ensure your ethernet is plugged in). If you haven't changed from the default login details, you'll find them in the router manual.
Wont connect to internet
Yes you hve to setup the router again, the wireless setting especially.
Turn mac control off in wireless security and let me know how you get on.
Samsung bd-p1600 wireless connection to 2wire 1800HG router
Check CNET Samsung forum. There are several posts with the same problem. A couple solutions and basic confirmation that Samsungs newest fireware is bad. I wish their support helpdesk would realize that instead of telling me to contact my router support.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
