you can start by looking for a speaker adapter on amazon. To ensure compatibility with your samsung tv, you can provide the specific model number to the seller so that they can check on their end. And you can also call the manufacturer of the product to ask them to verify the compatibility with your tv as well.
Unless your DVD/VCR is Upconverted to use HDMI, then you would use either the RED/GREEN/BLUE + Red /White leads to your TV and then use the TV remote to select whichever your TV names that input. If it is Upconverted, then simply plug the HDMI cable into a spare HDMI input.
Utilize the MiFine AV. This is a great product I have used many times located here or anywhere you can find it. I have only used this brand as many other reviews have stated they have problems with the cheap ones from China.
Mifine AV to HDMI HD Video Audio Converter 720p 1080p Mini 3RCA Composite CVBS to HDMI Switcher Portable AV2HDMI Adapter for TV/PC/PS2/PS3/PSX/Blue-Ray DVD
I purchased one for about $30 USD and you can use if for any device that has RCA cables such as a video recorder, VHS player, Wii, etc
Your TV is probably older and has Component, Composite and DVI connectors. HDMI is a newer connector that integrates sound. If your RPTV does not have HDMI but DOES have DVI, you can get an HDMI to DVI adapter on eBay or a computer store pretty cheap. You will need another way to get the sound from the Blu-Ray player, either external speakers connected to the player, or stereo RCA cables from the player to the TV (there will be a set of RCA audio plugs with the TV's DVI port).
If you are using HDMI cable you will not be using the YELLOW RCA plug sine the Yellow pug is for composite video. Analog audio uses RED (RIGHT) and WHITE (LEFT) for sound.
How exactly youhave the whole thing setup? through the receiver or just between the TV HDMI port and the HDMI port on the DVD player?
You will also need to setup the HDMI sound set up to send the sound through the HDMI cable or through the audio analog RCA ports.
More info needed. Hook up per DVD and TV user manuals
The best quality would be a HDMI cable, if your DVD player has a HDMI port on the back.
Any of the HDMI ports on the TV can be configured to take the audio over HDMI (digital audio) or over a separate rca stereo patch cable (menu option in the TV for analog audio).
So if your DVD has HDMI, just buy a HDMI cable and you're done. If you cannot figure out how to switch the audio input, there is no big harm in just installing a separate RCA patch cable between the two for the sound.
The next-best would be a component-video cable (Red/Yellow/Green) RCA cable, with a separate red/white RCA audio cable.
Alternately, if your DVD has a S-video port, that is comparable to component video. Then you would need a separate audio cable as well.
Last but not least, if your DVD player is ancient, it may only have a yellow video out connection, then red/white for audio. You then just need a standard yellow/red/white RCA component cable.
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
