MY NISSAN QD32 ENGINE IS OVERHEATING.I HAVE CHANGED THE FOLLOWING PARTS BUT THE PROBLEM IS THE SAME;WATER PUMP,RADIATOR,CLUTCH FAN,CYLINDER HEAD GASKET AND SKIMMING OF THE HEAD.WHAT COULD BE THE PROBLEM?HELP ME
air trapped in engine let it run with cap off it will burp a few times then it should be good
SOURCE: 2000 Sunfire coolant problem. Engine overheating,
ok, its time for a radiator flush. there is major sludge in the internals of this radiator. Make sure the thermostat is in the correct position as well. I've seen many cars come into my shop with the thermostat inserted backwards.
SOURCE: i had my 4g63 engine changed to a 4g64 in my
Not to sound too basic, but what shape is the thermostate in and is it in properly? I have seen them placed in up-side down before. I'd check it or replace it, be certain of proper temp for thermostate
Thanks,
Tom
SOURCE: 2001 grand cherokee running hot , replaced water
If it is the 4.0 engine there have always been bad to have a cracked head,right between the valves in one of the cylinders.
SOURCE: Toyota Tazz 1300 2004 overheating - Have replaced
have you replaced the thermostat? This controls the engine temp
