My TV is now set to 720. I would like to change to the highest resolution possible.
By the way, if you need some 4K UHD content, you can use Leawo UHD Copy to copy 4K movie from UHD discs.
Today's TVS are mostly IN 4K, but sometimes the picture is blurry and of poor quality. You want to set the definition of your TV to get a better picture. Most TVS don't need to be set up because it's not the problem of TV, it's the source.
Whether it is TV programs or movies and TV series on the network, the first thing to see the source of the resolution, the closer to 4K, the clearer, the better the effect. Conversely, the effect is poor and fuzzy. Because we basically need not the effect in the picture in the picture, full screen plays the effect not ideal again, so now TV of big size liquid crystal has watch a distance. It looks good at a distance. If it's not clear, the source is too bad and the resolution is too low to change.
BTW, you can also watch 4K video ob PC and then playback with free 4K video player. Here is the recommendation.
www.leawo.org/tutorial/5-best-4k-video-player-software.html?fixya=1410
I had an LG tv before and had this problem because 720p resolution wasn't enough for me. I can recommend you to find your LG tv model at http://lg.manymanuals.com/
You can choose the necessary manual and find out hot to change to higher resolution.
It depends on your source video resolution. If you're willing to play in 4K, you can upscale your 1080p or 720p video to 4K resolution in advance. Here is the video tutorial:
After conversion, it will be played in 4K on your TV. Of course, it's all based on that your TV supports 4K.
LG's plasma, LCD as well as an LED Televisions deliver an amazing entertainment encounter in the comfort and ease of your house. LG ELECTRONICS also offers the actual innovative 84 " UHD 4k TV Deals along with double the resolution of a regular HD TVs and also the spectacular OLED TV having an infinite contrast ratio. In addition, with the Smart Televisions and 3d-tvs, you are able to connect with the web or change virtually any development into a 3D experience.\
Check more details: http://4k.com/tv/
You cannot change anything from the tv side. TV automatically select the resolution based on the content you are playing. Play a 4K video the tv will take care of it.
