If this happens after first ten minutes your monitor need some repair.
PC Servis Kompjutera Kod Fontane Popravka Odrzavanje Laptop Desktop...
SOURCE: Power button won't turn monitor off?
Alternative : Download Turn Off Monitor Utility from http://www.monitoroff.com
SOURCE: Blinking Orange LED light on E151FP monitor
This monitor is know for a lot of parts that go bad, luckily they are usually the same ones.
If you are a technician or know one who can help you. Below is a list of part to repair/replace once the case is opened. (dont try this if your unfamilier with working on electronics.
1) F601= 2A Fuse
2) C605= 68uf 400v (must change)
3) R615= 0.68ohm 1watt
4) Q601= SSS6N60A
5) R613= 1Kohm 1/8watt (value changed to 2.3Kohm or higher)
6) R623= 4.7ohm 1/8watt (value changed to 7.2ohm or higher)
7) D604= 1N4148
8) IC601=UC3842B
9) C707 & C703= 1000uF 16V (must change, because of bad ESR value) secondary filter capacitor.
This problem of dell e151fp lcd monitor, you just need to resolder the inverter section (bad points or dry joint) and also check the capacitor value with ESR meter. It will solve your problems.
SOURCE: Dell Monitor Not Working
well if the status of the LEd on the monitor is amber(orange) & the system is running on a on board video card & not a Add-on video card... it is a possibility the the integrated video card ot the mother board might have gone bad... either contact a local tech or the tech support for the computer...
also unplug the monitor cable from the system tower & then if you see that there are the bars moving which say monitor self test on... means tht the problem is with the video card or the mother board...
since the system is running on a integrated video card...
SOURCE: Dell 2000FP monitor black screen
I just fixed my Dell 2000FP LCD monitor and right now using it.
The solution is very simple and easy. Do it your self if you are comfortable soldering.
Resolder the 2 transformer legs ( 9 legs each transformer), 2 oranger capitors, 2 small green capitors, 2 inductors coil legs.
Use at least 45 watts soldering iron with a pointed tip. Be careful.
Roan
SOURCE: Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
