Sony Bravia® VPL-AW10 Projector Logo
d
dan patterson Posted on Jan 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony bravia vpl-aw10 lamp come on runs for 2-3 mins then switches of and lam p cover light flashes 3 time repetedly
The lamp lights up pciturew comes on looks great only work sfor a few mins than switches of and lamp cover light flashes three times repeatedly if i hit the on button projector will come back on and work for a few mins again the turn on and flashing lights start again
cwradio73
Level 3:
  • Master 1,162 Answers
  • Posted on Jan 28, 2015
cwradio73
Master
Level 3:
Answers
1162
Questions
0
Helped
363852
Points
3460
Here is a link to the manual. It states you need to replace the lamp because it has reached it end of life an over heating.
https://docs.sony.com/release/VPLAW10.pdf
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
1helpful
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
I just replaced a bulb in my sony vpl aw10 projector, and now it wont power back up. The bulb/cover light blinks, and it powers back down. Any ideas? Help!
Bulb is not seated correctly of cover is not on correctly.
Please dont forget to vote this answer was helpful
Many thanks
2answers
I have the model name on screen and can't get rid of it, this is a VPL-AW10 Sony, what i should do?
Check out Display in the menu. There should be an option to disable this display.
How do i remove my projection lampfrom my sony bravia 60" tv
you jest reverse the projector and you can see the flat screw loos it and you will rise the loker and pul it up ward and do not touch by your finger the lamp if it is 2000 hours working whit the projector you shuold replace it
2answers
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
2helpful
1helpful
2answers
Sony CS5 Wont turn on
the cover switch is probably not fully made.
Ensure that the cover tangs are pushing the pin
on the miniswitches.
Try putting slight pressure on the fan or lamp cover to see if the lamp/cover light
stops flashing.
you will need to do a restart on the PJ to check this out
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
