Insignia NS-L32Q-10A 32 in. HD-Ready LCD TV Logo
R
Robert Schaub Posted on Jan 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I hookup an audio output for wireless headphones with either rca cable or 1/4" adapter?
Going from tv to a radio shack wireless headphone.
charles chandler
Level 3:
Master:
  • Master 530 Answers
  • Posted on Feb 18, 2015
charles chandler
Master
Level 3:
Master:
Answers
530
Questions
Helped
94613
Points
1633
Look on the back of the set for the AUDIO OUT PUTS!!
Where do I hookup an audio output for wireless hea - section-abbnzt3fc3fyhw05r0qorfnc-4-0.jpg
1 Related Answer
Anonymous
  • 1894 Answers
  • Posted on Mar 09, 2009
SOURCE: How to connect headphones without a headphone socket
if there is differentiation between the sockets you will need the manual..
3answers
What are connections and connectors for audio output to wireless headset
Hi Richard,
First, you'll need to determine which type of input(s) the wireless headset transmitter has. Most common is the 3.5mm stereo plug designed to slip into the headphone jack of a TV, MP3 player, cell phone, etc. Some transmitters have adapters in the box to allow connecting to the Left and Right channel RCA / phono style jacks found on other components such as CD, DVD, VCR, Stereo receivers / amplifiers, etc.
You'll need to find OUTPUTS of the CD and TV that match the plug on the wireless headset transmitter. If yours doesn't include adapters to go from say the RCA jacks mentioned above - to whatever connector that the transmitter input has - you'll need to go to your local Radio Shack store or similar store to see if they can provide an adapter that will allow you to connect.
Here are a couple plugs / adapters:
Above: A "3.5mm stereo patch cable". Your transmitter may have a cable with an end like this to plug into the TV's headphone jack.
25683604-gy4zxbmnj5ndu14q12lmwneo-2-1.jpg Above: A "3.5mm female stereo jack to RCA stereo male plug" adapter that would allow the top cable to connect to the Left and Right audio output jacks on a typical CD, DVD, etc. device.
These cables / adapters are typically $5 to $10 maximum.
I hope this helps and good luck!
1helpful
4answers
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
How to hook up headphones to a sharp 27ns100
It looks like your TV has stereo AUDIO OUT jacks on the rear panel (L and R) which you can use to connect headphones. Go to a local Radio Shack or other electronics retailer and ask for help with the required adapter cable and connectors. They should be able to direct you to the product(s) as Radio Shack has these simple adapters and they should cost very little. All you need is a simple RCA cable with the white and red plugs for the TV side and depending on your headphones, either a 3.5mm or larger connector for hookup on the headphone side. They also sell extension cables so you can move away from the TV more. Don't let them sell you anything fancy or expensive as this is really simple.
How do i hookup my speakers to my tv
Computer speak usually have a 3.5" headphone plug (just like a pair of headphones). This plug is not native to a TV, they instead usually use RCA plugs (red and white with a solid center post and metal 'sleeve' which makes the connection) these are the most common audio out format for most TVs. You can go to radio shack and buy a 3.5" headphone to RCA adapter which is just a short cable with a female 3.5" plug at one end and two RCA plugs at the other (red and white). This is pretty cheap ~$5 and should get you up and running. You will be going from the label Audio Out ports on your tv through the adapter cable and into your PC speakers.
4helpful
Does my sanyo tv model DC26640 have a place for headphones?
Looks like your Sanyo DP26640 does not have a headphone jack in the traditional sense however it does have two audio output jacks (left and right) for RCA audio cables which would typically go to an amplifier with speakers. If you want strictly a headphone, what you can do is go to Radio Shack and buy an adapter cable for less than $10. You can get adapter cables for 3.5mm plugs and others. Plug your headphones in and you can listen. 3.5mm female and RCA male at the TV side.
2answers
How can I connect headphone line from delta 1010LT sound card?
on output of sound cardsare coloured sockets,headphone/speaker socket is green
2answers
Hooking up wireless headphones into the tv
u have to split the signal by having both the tv and the headphones getting the input,as you're probably only have the audio cables going to the headphones.You need an audio splitting cable (it has 4 malle connections) so you can put 2 in the tv and 2 in the headphone base.
2answers
Logitec Wireless Headphone
If there is an RCA output (red & white), you can get an RCA to 3.5mm mini jack adapter at a store like Radio-Shack in the US or the Source in Canada.
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
