Kitchen Ranges Logo
c
charlene smith Posted on Jan 27, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant get my stove to stop beeping. f1 error
F1 error keeps beeping
biire2u
Level 2:
Sergeant:
  • Expert 137 Answers
  • Posted on Jan 27, 2015
biire2u
Expert
Level 2:
Sergeant:
Answers
137
Questions
Helped
40333
Points
531
You need to get the exact model number and make of this stove. Get ready for a bad circuit board to be the culprit, because electronic stoves are pretty much unfixable by mechanical means and the problem usually comes from a bad capacitor, corroded or overheated circuit board.
When you get your model number and make, go to YouTube and just type in your model stove and ask "how to repair a F1 error code on a blah blah stove". There are so many video's there on how to repair things with actual instructions and pictures. It's great.
Use this link to close in:
https://www.youtube.com/results?search_query=repairs+to+appliances+or+stoves
What causes the beeping sound coming from my Hearthstone propane stove? I bought my Hearthstone propane stove secondhand.
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
2answers
My F1 Code keep beeping.
I think you must post full information about your stove
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
My stove has F1 on the screen,and i beeping. I
Sorry it can not be reset.
The F1 code is a failed electronic control. The clock/oven control must be replaced.
6helpful
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 • Ovens
1helpful
Error code F 1 stove beeps
Hello rusalderman,
Welcome to fixya.
Happy to help.
You said, your range has an error code F 1 stove beeps.
This should reset the system.
A Solution to Common Problems
Oven control beeps & displays any F code error (for example
F1) - Electronic control has detected a fault condition.
Press CLEAR/OFF to clear the display & stop beeping.
Reprogram oven. If fault recurs, record fault number. Press CLEAR/OFF &
contact an authorized service agent.
This should resolve your problem and reset the system.
Please remember to leave a rating when you are finished.
Let me know. Hopefully it will be a solved.
Thank You , Huuum
"F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Tappen gas 4 burner about 10 years old with about 10 hrs total use time(basement stove)
Hi Carlsr,
The F1 error code description is an electronic oven control failure. To fix this error, you need to replace electronic oven control (also called EOC or clock).
Hope it helps.
Thank you for using FixYa.
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Top Kitchen Ranges Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
john h
Are you a Kitchen Range Expert? Answer questions, earn points and help others
