It should just slot in one way only. Try it 180 Degrees around.
If the timing between the Needle and the hook is wrong, when the needle is about to lift, set the hook to be about 3 degrees off the needle line. This position may need tweaking but is usually about right. Thread the needle and manually turn the machine. The needle should lift and the cotton should loop for the hook to pick up.
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem.
it's possible that when the left needle broke, it could have caused a missalignment in the machine, it would be a good idea to have the machine checked.
try these suggestions Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Skipped stitches
if you can send me the model number of the machine,, I'll see if singer has a free downloadable manual
the best thing would be to take the machine to a sewing machine shop & have them check to see what's wrong with the needle holder, cause if there's a something broken it will have to be replaced
It sounds to me like you have replaced the broken needle with one that is too long (wrong size).Check your manual for the proper needle size and look through your collection, or head down to the local sewing shop and pick up a new pack of proper sized needles. Now if the needle you replaced the broken one with is the same size, you most likely didn't loosen the set screw up enough and therefore didn't slide the needle up far enough before locking it in. Double check this.
Not knowing what type of machine you have I just have to say there are three letters to remember... T-N-T. Thread, Needle, Tension.
Since this is obviously not a tension problem you have to make sure the machine is threaded correctly. Incorrect threading will cause this as will the bobbin in upside down and turning the wrong way. Then there is the needle. Be sure it is inserted properly. My opinion is the needle is in wrong or the bobbin is turning the wrong way. Good Luck.
Rick
