J
Julia Chindongo Posted on Jan 27, 2015
How can i resolve error000-0000
I have tried to switch it on and off again but nothing is happening because the screen is displaying that turn the main power on and off. if the device does not recover contact dealer or service representative. E000-0000
  • Mamun Rahman
    Mamun Rahman Sep 21, 2017
    please tell me what can i do
BINOY.P.VARGHESE
Level 1:
New Friend:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jan 28, 2015
 BINOY.P.VARGHESE
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
8
Questions
0
Helped
484
Points
15
Kindly provide your details about your mechines
  • Julia Chindongo
    Julia Chindongo Jan 28, 2015
    The mechine is IR2202n canon
  • Mamun Rahman
    How the solve when if device does not recover , contact your dealer or service rep turn the main power off and on E000-0000
I have a sony va10 F series notebook model VPCF115FM, it was working fine at first but when i shut it down and then later turne it on again, it does nothing...nothing appears on the screen, all i get is a...
It appears that teh computer has entered the sleep mode and not waking.
Press and Hold the power switch for 7-10 secs to turn OFF the computer and again press the power to turn it back ON.
If issue is still not resolved then perform a few more steps for computer booting to black screen.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C270032
You can also perform the steps from the below link for computer that does not wake from sleep mode:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1002369
After this, change what happens when the physical power button is pressed or when the notebook lid is closed settings. Follow the steps from the below link.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1002901
Select the option of shutdown for power button and do nothing for the close lid option.
Performing the steps provided can resolve the issue successfully.
4helpful
Hi! The Belinea 1705 S1 monitor screen turns off after about 15 seconds. If I turn off and on, again it happens. I tried to enter the menu, but the OSD-LOCK displayed. What's the problem and the...
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"....if the problem continues. Switch of the monitor and remove the power cable and connect it again.
hope this helps and good luck with the problem and by the way don't forget to vote for this solution.
Its an 8gb.i had it plugged into the comeputer it
just remove the any usb pen drive which is connected to the cpu and try to switch it on .if there is no display remove the ram and try to fix it again.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
My phone just went dead. If I try and switch it on, I can feel it vibrate but nothing happens.
The display of the phone is damaged. Thats why when you press turn on its vibrate But screen not come. Replace the screen its will start work again.Thanks.
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
2answers
I dropped my n95 and now it will not switch on it makes a noise but nothing happens ie screen doesnt light up
May be you display is with a problem. Visit the nearest Nokia care and the service personnel should help you out..
Thnks - billa
3helpful
3answers
No Resource Upgrade resource agan
ok, so u formatted your player, hence the green screen. So now all you have to do is download the firmware(match your player, sl with sl firmware, etc) then extract w/ winrar, u get 2 files so put them both in root folder (displaying music, video, etc) unplug turn off, on it will update then wait few min till it turns off, then turn on and ur player will work.
k24674
ADMIN Andrew
ADMIN Andrew
