Question about Pioneer Audio Players & Recorders
According to manual there is pre/amp on Pioneer sx 20 what connections do I use to connect graphic equaliser
    Habit-Forming:
  • 166 Answers
Yes, the SX20 includes a preamp including a phono stage. (nice!) There is already equalization in the SX20 available via the bass/treble controls. To hoop up an external graphic equalizer, you should be able to connect it to the 'Recorder' IN/OUT and then select the tape monitor input to hear the equalized signal.
http://www.hifimarket.cz/files/img/zbozi/pioneer/_640x480/sx-20-4.jpg
Posted on Jan 28, 2015
6ya staff
SOURCE:
Anonymous
  • 11 Answers
SOURCE: I purchased a pioneer SX-315 theater system. My
get a male head phonejack with rca ends...
Posted on Jul 12, 2009
Anonymous
SOURCE: owners Manual for a Pioneer SX-315
http://safemanuals.com/user-guide-instructions-owner-manual/PIONEER/SX-315%20-HTP-2500--_E
Posted on Sep 15, 2009
Sam
  • 3247 Answers
SOURCE: My Pioneer Receiver (SX-255R) won't
Just to be sure we are talking the same unit I have included the link to the user manual for SX-255R
http://www.pioneernz.co.nz/Site/Pronto/Files/user_manuals/SX255R%20USER%20MANUAL.PDF
Suggestions
1. have you tried to press the Muting button on the remote unit.
(item 11 remote unit diagram)? does it make any diffrence - what if the button is stuck?
2. Have you tried to play the Tuner radio - what happens then? do you still get Muting.
3. You mentioned something about speaker wire coming out.
I understand that Pioneer receivers shut off if any of the speakers is faulty, ie, correct impedance is not showing at the speaker input point.
Usually the newer units give an "overload" message. It is possible this could be happening and the SX-255R gives the "muting" message instead. Some people have reported very minute shorts where strands of the speaker wire touch the body and it causes "overload".
One way to check is to remove speakers wires one by one and see if the "muting" goes away. Then you can check the offending speaker if that is what is happening.
Good luck
Please do drop a comment to say how you progressed.
Posted on Jan 02, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Can I connect my pioneer SX-255R stereo receiver
Yes, but it depends on your laptop hardware and software. We'd need to know a lot more about that side.
Posted on Jan 21, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: pioneer sx-255r can i connect 6 - 8 ohms
Yes, you can use them but be careful. These are not necessarily robust speakers. If they sound strained, back off.
Posted on Mar 08, 2011
How do I connect a yamaha m4 thru my pioneer sx 838 so I can use the pioneers controls
You need to disconnect the bridges on the PRE/POWER AMP connectors and connect PRE OUT connector to your M4 input connectors.
Jan 10, 2015 | Pioneer VSX1021K 7.1 120W Digital Reciever
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
Hi want to connect bose 901s with active equaliser to my pioneer sc-lx81
According to this picture, you're in luck BUT...
http://www.avland.co.uk/pioneer/sclx81/rearlrg.jpg
(Short answer from personal experience.)
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers. A good 100-wpc amp will do. (I like Carver)
Connect the Active EQ between the Front pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Helpful Hint: If you don't have sufficient between-speaker room for proper reflection off the front wall you CAN turn the 901's around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Oct 09, 2010 | Bose 901 VI Main / Stereo Speaker
I just purchased a used SX 3800 Receiver and upon viewing the back panel, suspect a pre-amp maybe required. What is required or compatible? This is a first for me.
HI... NO pre-amp required.
Pioneer made it so you can send the pre-amp signal to a larger power amp ( if you want to)...Either there is a switch to jumper the "pre-out" to the "power in" jacks OR you need to connect a couple of RCA (phono style) cables between them
Oct 03, 2010 | Pioneer Audio Players & Recorders
How to wire up kenwood ge-760 graphic to my
First of all connect the source, the tape or the DVD, to the input of the equaliser, use the output to connect to the AUX of the amplifier. make sure that the L&R are not crossed over. In case your amp has an in and out of the preamp section use then connect the source to the amplifiers input specified for the source like tape or DVD or TV and use the preamp output to the equaliser input and the output of the equaliser to the input of the main ampflier. Now the bass and treble of your amp can be set to the mid point - 12 noon position and use the boost or attenuation according to your choice of music. hope you find my advice helpful. Good day
Jul 04, 2010 | Kenwood Audio Players & Recorders
How to connect my realistic 7 bands equalizer to my amps .
Since you have not mentioned the amplifier I am not aware if the amp does have an preamp input and output. In case you have these then the output of the preamp of the main amp must be connected to the input of the equaliser and the output of the equaliser must go to the input of the main amplifier. The sources can be connected to the amplifer according to the selected device.If your amp does not have the preamp input/output then connect the source to the input of the equaliser and the output of the equaliser to the aux of the main amplifier.Now set your amp's bass and treble to mid point and set yout equaliser accordingly. Hope this helps. Good day
Jun 05, 2010 | Audio Players & Recorders
Pioneer SX-950
use a cable tester for the wires that are connecting to the unit and you'll find the faulty wire that is bad.....good luck
Nov 03, 2008 | Pioneer AVIC-S1 GPS Receiver
Connection of Amp to Equaliser
Thanks guys, but i solved my problem, i experimented and decided that i would run my DVD player (Aux Out) as a CD player through the Equaliser in [Rec] and from equaliser out [Play] i went into Tape Play on Amp, then i connected my Turntable CD Radio System to the Tape 1 Rec on Equaliser and then from Tape 1 Play on Equaliser went into the Tape 2 on AMP then i could use Aux in on Amp to connect my Laptop via my laptops headphone socket my laptop has an equaliser so i didn't need to connect to pioneer EQ, i also connected a small 5.1 to the DVD's 5.1 and connected 4 *45w Speakers to the AMP. and i can say it was FANTASTIC i couldn't get to 5 on my volume it was un @$#%believable.
My Quote
"Where there's an In, there's an Out".
Aug 30, 2008 | Audio Players & Recorders
124 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Anthony
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
